Spark and pickup coil question
Old Apr 2, 2010 | 07:56 AM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
My car won't start. It cranks over fine but there is no spark coming from the plugs. I have already replaced things like sparkplugs, cables, rotor, cap, ignition module and coil but still nothing. I've been reading here about spark problems and seen pickup coil beeing brought up. Can this be the problem? Also, does my car even have a pickup coil? How can I tell when I'm not sure what it is? A picture would be great. Not of just the coil but the distributor as well.
My car is an '89 GTA with the LB9 engine (305 TPI).
Old Apr 9, 2010 | 12:05 AM
8587ta's Avatar
Car: '91 Firebird
Engine: 468 BBC w/ 8-71 blower
Transmission: Th400
Axle/Gears: 9-bolt 2.77
Re: Spark and pickup coil question
I had a problem with my car only starting once in a while and it would miss last year, I replaced my pickup coil and it ran perfectly afterwards. I know it wasnt too expensive. From what I know if you look under the rotor, and there are not the springs and weights in there, and you should have the HEI type set up? The pick up coil is connected to the ignition module (which may need to be replaced as well) and it is under everything. I would post pics if I had any. I only have my old pickup coil
for pics.
Old Apr 9, 2010 | 12:27 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
the easiest way to replace the pickup coil is to drop in a whole distributor. all of these cars have them stock. it has the same function as a cam sensor.
apo_bailon15
Mar 28, 2016 05:20 AM
Winchester1094
Aug 18, 2015 10:23 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
