wipers help!
Old Apr 3, 2010 | 05:10 PM
1988350bia's Avatar
Car: 1988 camaro SC
Engine: 355 four bolt
Transmission: th350
wipers help!
just bought an 1988 camaro sc, and the problem im having is the wipers will turn on and work fine, but when i shut them off they dont turn off, they keep going, until i shut the car off and turn it back on will they relax back onto the cowl.I replaced the motor and the switch.
let me know?
Old Apr 3, 2010 | 05:16 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
Re: wipers help!
it could be..................the wiper motor module
Old Apr 3, 2010 | 07:16 PM
1988350bia's Avatar
Car: 1988 camaro SC
Transmission: th350
Re: wipers help!
i just had it replaced, is there a way to check it?
Old Apr 5, 2010 | 01:20 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
Re: wipers help!
the wiper motor and the module are two seperate units that are bolted/screwed together if you changed the switch by the steering wheel and the motor and the module then you shouldnt be having any problems. as far as checking it...................
Old Apr 5, 2010 | 01:39 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
Re: wipers help!
Wiper Will Not Park
  1. Turn ignition on and wiper off and probe harness terminal No. 2.
  2. If light illuminates, refer to wiper switch continuity test.
  3. If light does not illuminate, remove wiper cover, reconnect motor without cover, switch motor from LO to OFF and check whether park switch latch arm is in position to catch drive pawl.
  4. If arm is not in proper position, replace park switch or, on pulse models, the cover assembly.
  5. If arm is in proper position, check whether drive pawl is bent.
  6. If drive pawl is bent, replace it. Otherwise, check shaft endplay. If drive pawl overrides latch, replace shaft assembly.
Old Apr 5, 2010 | 07:21 PM
1988350bia's Avatar
Car: 1988 camaro SC
Transmission: th350
Re: wipers help!
thanks alot ill give that a shot.
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
