Help with coolant sensor please
Old Apr 4, 2010 | 07:24 PM
ToddN's Avatar
Hi folks.
First, great site here. Heres my problem. i have recently aquired an 85 K10 with about a 1990 350. I'm slowly redoing the hack jobs that the kid before me did. I noticed that my temp guage wasnt working so I started investigating. I found that the coolant temp sender down between the spark plugs was in bad shape. I replaced it. No problem. Then I went up to the coolant temp sensor up by the intake and half the clip is broken off with one prong and the plug is still secured. I bought a new one and screwed it in. Heres the problem. There is absolutley nothing in the area to plug or splice the two wire pigtail into. What should I do? Ive looked and looked to see where the old one is and I cant find it. Thanx!
Old Apr 4, 2010 | 09:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help with coolant sensor please
what wiring harness does it have?
Old Apr 4, 2010 | 09:34 PM
ToddN's Avatar
its hard to even tell. Its been seperated and electrical taped...I'm slowly unraveling and straightening things out though. I couldnt even tell you by looking at it. Interestingly, absolutley everything on the truck works.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
BWilcox
Sep 20, 2015 12:19 PM
FormulasOnly
Sep 10, 2015 09:07 PM
