86 Trans Am TPI Overheating
Old Apr 5, 2010 | 09:58 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
I have a 86 Trans Am, The Problem is with overheating, ill start and drive and it will be a 220 on the temp guage for a while, but when i get on the high way and start to go fast it starts to go up, it usually sits right in the middle of 220 and the red zone on the temp guage sometimes it does this with regular road driving as well and when I go faster like 70 or 80 my t/a gets closer to the redzone, but when i slow my vehivle down it will go back down to 220 and sometimes just a little below 220, I replaced the thermostat and radaitor and it is still doing it, and my antifreeze always appears to be full, when i popped open the hood while the temp guage was up the fan seemed to be working fine, I really wanna find out the problem is before I ruin my engine, could someone please help!!!!!!!!!!!!!
Old Apr 5, 2010 | 10:06 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 86 Trans Am TPI Overheating
make sure the air dam is there. make sure the condenser (if applicable) is not causing air blockage.
Old Apr 5, 2010 | 10:09 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
check your timing and make sure you don't have an air pocket...
Old Apr 5, 2010 | 10:32 PM
dredre08's Avatar
how exactly do u do that, but i do think my timing is off
Old Apr 7, 2010 | 11:30 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Something to keep in mind........
City overheating is usually an Airflow issue
Highway overheating is usually a Coolant flow issue
So....
A plugged rad 'may' stay cool enough in the city but overheat on the highway under really heavy loads
A bad Fan may not work in the City but your system will work great when you go above low City speeds or on the Hiway.
Decide when your system runs Hot.
Again.....the general rule is
Overheat in the City....not enough Air Flow.....bad air flow or other issues related to fans
Overheat on the Highway....not enough Coolant Flow or low system blocked rad low coolant list goes on
Old Apr 7, 2010 | 11:35 PM
Gregzz4's Avatar
Sorry, after re-reading your post........
It sounds like your Radiator may be plugged
When you drive in the City it acts OK, but when you go on the Highway it gets hot
The faster you go the Hotter it gets
You back off the throttle it cools down
If this is your situation, your Rad is Plugged
It can't flow enough Coolant to cool the demand you are putting on the Engine and it will heat up
Fix/Replace the Rad
Good Luck
Greg
mustangman65_79
Sep 1, 2015 03:51 PM
beachrodder
Aug 25, 2015 08:05 AM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
