Need help with roller cam conversion
Old Apr 8, 2010 | 03:00 PM
Dmity Kiev's Avatar
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Hello guys , need some more info about roller cam conversion . 350 SBC 1 gen in 95' G20. what parts I need , what machined work i need ? I read article http://www.chevyhiperformance.com/te...cam/index.html and have some questions
1. cam? - already have LT1 cam
2 lifters - do i need to use retrofit lifters ? like this http://www.summitracing.com/parts/HRS-91164N/
3. do i need to replace timing chaing cover ?
4. do i need to replace timing chain to roller or double roller ?
5. do i need some modifications with valve spring if motor get new GMPP Vortec heads ?
6. what size of pushrod i need ?
Thanks , maby someone have some pics of this conversion it will help us.
Old Apr 8, 2010 | 03:14 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Need help with roller cam conversion
Is the motor a 1 piece rear main seal or a 2 piece? If the block is a one piece and has the bosses in the lifter valley to accept the hold down pieces, then you can just try to find those factory pieces and use them. If your block is like mine, which was a 1 piece seal block but does not have the bosses drilled or tapped, you will need to either drill and tap the holes, or get retro-fit lifters for a late model block. These are normally a decent amount more expensive than ones made for earlier blocks. If you have a 2 piece rear main block, then you will need the retro-fit lifters.
The timing chain cover doesnt have to be replaced, but you do need to run a cam button in front of the cam inbetween the cam and the cover. You will need to make sure you have propper clearance here. I would run a double roller chain.
Pushrods I'm not sure on. You could always buy an adjustable pushrod and then measure for your motor. This is what I did.
Old Apr 8, 2010 | 03:40 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
1. That cam will work, with LT4 style retainers https://www.thirdgen.org/forums/tbi/...ml#post3089487
2. depends if your block is machined for the "Lifter Link Bars" http://www.summitracing.com/parts/SUM-150121/
3. If you can use the cam retaining plate, there is no need for a special timing cover.
4. For the LT1 cam you dont really need a double chain. This will do its duty nice http://www.summitracing.com/parts/NA...1043/?rtype=10 and it comes with 2 types of cam retaining plate.
5. Vortec cam has a little less lift then a LT1 cam, best is to investigate what lift the springs on the heads support.
6. Probaly the same as the L31 engines, best is to measure with someting like this http://www.summitracing.com/parts/TFS-9000/
This is a pic of a roller sb https://www.thirdgen.org/forums/atta...759-288-ko.jpg
Old Apr 9, 2010 | 01:59 PM
Dmity Kiev's Avatar
Car: Firebird 91
I have few photo of the engine . it seems to be machined for Lifter Link Bar
So i steel need retrofit lifters or I can use standard SBC lifters and pushrods , like L31 or something ?
Old Apr 9, 2010 | 04:28 PM
thomas1976's Avatar
Car: 91 Trans am
Yes thats a roller block. Stock type roller lifters, spider, lifter link bars and cam retaining plate is all you need.
Pushroad lengt can change, depending on heads, rockers and maybe lifters?
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
