Two quick questions. (Serpentine Smog Routing)
Old Apr 11, 2010 | 07:49 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I've got a 87 IROC that I swapped to the serpentine setup on, only to find out I needed all of the smog parts as well as the accessories. I got sent the parts from a 89 350, and I can't figure out where the big hose goes that connects the driver's side and passenger's side AIR tubes together with the diverter valve. I have it routed so that it works, but it seems far from optimal, and isn't in the same shape the part was when I got it, which I assume was baked that way from sitting on another car.
Pics:
Edit: Second question, if I run this rubber hose behind the engine like my old steel pipe was, will it hold up to the temperatures back there?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
codeysabatini
Nov 10, 2015 04:07 PM
racereese
Oct 10, 2015 09:39 PM
reactor60
Sep 22, 2015 01:44 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
