Heated 3 wire O2 conversion help needed...
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
I am planning on performing this swap as I believe it will help my header equipped car. I have a buddy thats very TPI savvy, but just in case he flakes, I was hoping of someone has either photo'd their swap or can walk me thru it with maybe with a wiring diagram. I had planned on picking up a new heated O2, and going to a junkyard and snipping an O2 harness off a vehicle to have something to start with.
Transmission: 4L80E/4L80E
A search for "heated O2" should produce the information. If you add member "Vader" to the criteria, that should help narrow it down to the more useful threads.
2012sergen11
Oct 13, 2015 07:38 PM
