need heater help
Old Apr 14, 2010 | 08:23 PM
joekaz1070's Avatar
Car: 1987 Trans am
Axle/Gears: GM 10 bolt
need heater help
have an 87 TA 305 TPI. One day heater works fine, next day fan blows normal just air stays cool. Engine sounds fine,temp. stays in normal range.
Any ideas?
Old Apr 14, 2010 | 09:52 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: need heater help
sounds like a heater diverter valve . ck. the vacuum lines going to it . it could also be the valve it self . easy to change , cheap , ready available , G.M. used the same ones on many models/years . good luck .
Old Apr 15, 2010 | 11:50 AM
Camarillo's Avatar
Car: 1990 RS Camaro
Engine: 1990 305 tbi lo3
any coolant smell in the cabin? syrup? wet floor on passenger side(heater core) if no, make sure about diverter, and also look behind the heater/ac box in dash for loose broken or disconnected vac lines
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
