Rocker Arms
Old Apr 15, 2010 | 04:07 PM
timespy's Avatar
Car: 91 RS Convertible
Engine: Soon to be swapped
Transmission: Memphis performance 700r4
Axle/Gears: Soon to be changed
Rocker Arms
Putting the finishing touches on my 350 build, and am in need of rocker arm advice. I have read the articles on 1.5 / 1.6 ratios, but am looking for info based on a real persons experience. I have installed a 488/ 488 lift cam, new springs, and goodies. The cam manufacturer rates the lift with 1.5 ratio rockers, and I know the 1.6's will increase the lift by a percentage. I have not done anything to the heads to allow them to accept a high lift. My question is..how high can I go without slapping the pistons, or better yet, will using the 1.6 rockers increase the lift to a point that will make the valves tap the pistons. The articles I have browsed put the h.p rise anywhere from 14- 25 hp between the 1.5's and the 1.6's.
I know to look for pushrod bind, spring bind, and retainer clearence. All of that should be ok.
Old Apr 15, 2010 | 05:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless you have very high compression, the valves aren't going to hit the pistons.
Spring coil bind and retainer-to-guide/stem seal are the important considerations.
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
