Is this the knock sensor?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Is this the knock sensor?
nope. that's a coolant temp sensor. the knock sensor should be low on the block, mid way back, passenger side, near the oil pan.
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Thanks, do you know if replacement connectors are available and from where. When I pulled the starter there was no surround on the wire, only the wire dangling around.
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
FormulasOnly
Sep 10, 2015 09:07 PM
