Distributor questions for 91 TPI
Old Apr 17, 2010 | 05:00 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
I'm trying to nail down the source of my annoying engine stumble throughout the lower RPM range. I don't think it's fuel or sensor related, and I'm guessing its spark.
I've pulled the distributor, but I'm confused as to what is what. My Haynes manual isn't helping a whole lot here. It is an external coil model, and I have already replaced the cap and rotor.
I'm wondering what I should be testing/replacing now that I have the distributor out? There is a large black electronic component with two external connectors, I believe one goes to the coil and one to the ECM. Then there is a two wire connector that goes into the distributor body. What is this component? Ignition module? Where do these wires go into the distributor? The connector just fell apart while I removed it, and the wires are a mess.
Anything else I should be checking while I have it pulled?
Old Apr 17, 2010 | 11:49 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Re: Distributor questions for 91 TPI
http://cgi.ebay.ca/RS03-DISTRIBUTOR-...item563a6ee8de
How about something like this? Seems like it would solve my problem, replacing all the individual parts like the module and pickup coil would cost more anyhow.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
