fuel pressure problems
Subscribe
Apr 18, 2010 | 10:51 AM
have a fuel pressure problem dont know if it is me or the regulator probably me it is a carb bbc with a electic pump jegs 130 also used a holley blue last year had same problem regulator is a aeromotive dead head style my issue is every time i set the pressure it changes in a couple of minutes and not just a little bit but like 3-4 pounds no matter how i set car running or not never had this problem before i feel a little stupid but i am lost any help would be great thanks alot
Reply 0
Apr 18, 2010 | 09:05 PM
Re: fuel pressure problems
nobody
Reply 0
Apr 28, 2010 | 07:34 PM
Is your voltage consistant at the pump?
Reply 0
Apr 28, 2010 | 09:26 PM
yes the voltage is fine i figured out the problem called aeromotive the guy asked if i had a oil filled gauge and i did he told me to drain the oil out of the gauge reset pressure and i would never have the problem again so i did and pressure is rock solid has something to do with physics
Reply 0
Apr 29, 2010 | 07:36 AM
Good to here!
Reply 0
Subscribe
