Replaced leaky left valve cover gasket
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Noticed some oil dripping onto my headers and was amazed the valve cover gasket lasted for 23 years.
After doing some research on the boards, a lot of people were having issues with Fel-Pro with fitting correctly and what have you. So I went to the Summit website and ordered the GM High Performance replacement gasket for the center bolt covers. It was a bit pricey for one at 23 bucks or so.
When I removed my ac compressor and moved some vacuum lines aside, the valve cover came off with just a little nudging. To my surprise, the old gasket is the same color and has the same design as the old. Fit like a charm with no issues. Bolted everything back on, and the leak went away. Just hope the right one doesn't go.
NBrehm
Aug 25, 2015 11:49 PM
Street Lethal
Aug 12, 2015 11:33 AM
