fuel coming out of the vacuum canister???
Old Apr 23, 2010 | 02:31 PM
blazindizz's Avatar
Want a title? Post!
ok, I have a 1988 Pontiac Firebird Formula. I have a problem, and no clue how to fix it, or to the fact whats even causing it.
About 2 months ago, i had a new fuel pump installed, and everything for a while seemed fine.
about this time i started smelling fuel, and my gas gage would drop fast like i was burning fuel like no tomorrow. I started looking around under the hood. really didn't see anything. a week later, it started acting like it was going to die. I looked at my canister, and noticed that there was afluid coming from the one port that has a cap on it.( the one closest to the fender) I didn't check it for smell, due to everything at this time smelled like fuel. when i pulled the top hose off, the car went back to running fine.
Today, i came out of a store and noticed a puddle by my tire. i checked it, and sure enough, it was fuel. I looked at the canister, it was streaming out the fuel. The bottom rubber line is being eaten away by fuel, its making it where i do not feel safe even starting it up.
Does anyone have an idea what could be causing this?
Old Apr 23, 2010 | 09:43 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: fuel coming out of the vacuum canister???
just a guess, but it sounds like the vent and return lines may have been swapped around when the fuel pump was replaced.
if it were me, it would be the first thing i would check.
Old Apr 24, 2010 | 08:22 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Old Apr 24, 2010 | 02:39 PM
fiero377ci's Avatar
Car: 85 iroc
Engine: 355 tpi
Transmission: 700
or if u have headers and a non heated o2 sensor it may not be going into closed loop to activate it.
Old Jul 15, 2012 | 06:44 PM
IBrockZ's Avatar
Car: 87 irocz 305 5.0 5 speed G92 option
Engine: 305 tpi
Axle/Gears: 9 bolt 3.45 factory gears
Did you ever solve this problem mine began finding it the other day.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
