can i make a Vortec 350?
Old Apr 25, 2010 | 09:25 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
I have a basic gen 1 SBC 350 bored 60 over decked (idk how much) and i wanna change the top end (except the cam).
Ok so i think i wanna get aftermarket vortec heads and edelbrock rpm air gap vortec intake... is that all i need to change inorder to run a vortec setup??? Will my header still fit? Will the distributer still work? Will I need to get different length pushrods because of the different angle of vortec heads? Thanks!
Old Apr 25, 2010 | 09:35 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: can i make a Vortec 350?
I built my Vortec engine, used regular old style pushrods, an older vacuum advance distributor, and headers that are made to fit older (non vortec) heads.
Others will chime in, but I dont see any problems.
Old Apr 26, 2010 | 05:21 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Ok sounds good. I have a StreetFire Vaccumm and mechanical advance distributor along with Comp Cam Pushrods because the block has been decked... the motor has no computer control left what so ever. Hopefully the headers will work.
I've got fabricated aluminum valve covers, i wish they had vortec heads that had outter bolt hold downs. Oh well : (.
Old Apr 26, 2010 | 07:35 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Yeah, you'll be fine with what you got. I did the same thing a couple of months ago.
Old Apr 26, 2010 | 08:00 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
ive got a gen I block bored 60 over, vortech heads and the rpm airgap manifold as well. its a nice combo if i do say so. i run hooker 2460s with no problems.
Old May 4, 2010 | 11:16 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
what about accessory bolts? Can i still run my traditional Gen 1 multiple belt setup? Or do i havta switch to serpentine. I only have an alternator and powersteering.
Old May 5, 2010 | 10:26 AM
You can run either V-belts, or Serpentine.
I have had both on my motor.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
