1988 iroc starting problem
Old Apr 26, 2010 | 12:04 AM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
Transmission: 700R-4
i have already changed the fuel pump and chack the fuel presure, it is fine but the car will not start without giving it some throttle, unless it hasnt been shut off for long, i changed the fuel pump relay and still no change, any ideas to what the problem is, i would like to fix this problem. it does throw the check engine light on occasion but nont often, also what work would be needed to put a 9.5.1 350 in place of the 305, i am not going for all out power just a bit more and maintain drivability. thanks
steve 704 796 1110 if you know what is wrong
Old Apr 26, 2010 | 07:00 AM
Vader's Avatar
Re: 1988 iroc starting problem
If you need to open the throttle to start the engine the problem may be flooding, not lack of fuel. Monitor fuel pressure while running and for several minutes after shutdown. If the pressure falls off to zero within 15-20 minutes there may be leakage from an injector(s) or the FPR. It's also possible the pump check valves are leaking but that is less likely with a new pump.
Old Apr 26, 2010 | 07:53 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Vader is on the right track. If it always starts faster if you give it throttle, it sounds like your engine is flooded. How much throttle are you giving it? Try holding it to the floor and starting it when you know it's not going to start good. If it starts much faster, then I'd say for sure you have leaky injectors/FPR.
My car only had 2-3 leaky injectors. And it was enough to have to give it two long cranks to start it, then it would stumble a bit from being flooded, and then idle ok.
Anyway, here are my fuel pressure readings when I turned the car off with leaky injectors:
Old Apr 26, 2010 | 10:16 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
[quote=IROCThe5.7L;4522898]Vader is on the right track. If it always starts faster if you give it throttle, it sounds like your engine is flooded. How much throttle are you giving it? Try holding it to the floor and starting it when you know it's not going to start good. If it starts much faster, then I'd say for sure you have leaky injectors/FPR.
Mine is doing the exact same thing and I know for a fact that at least some of my injectors are leaking. The starting issue is exaclty what you're describing as but the car idles fine and runs great after the initial stumbling. I bought a set of Bosch III's that I'm going to put in whenever I get a free weekend. I was just curious what effects you saw overall after replacing the injectors. Any noticeable difference while driving or at idle, or just improved starts?
I'm not trying to hijack this thread, just curious about your results. Thanks!
Old Apr 27, 2010 | 12:03 AM
Car: 1988 IROC-Z
Engine: 427 SBC
I sent all 8 to be cleaned and flowmatched. I honestly couldn't tell a difference in idle or performance. But it started much better.
Old Apr 27, 2010 | 09:26 PM
thedrewdotcom's Avatar
Car: 1986 IROC
if it still starts hard and there is a check engine light it may be a bad ECT sensor.
Old May 10, 2010 | 07:41 PM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
thakns guys i think i will just change all the injectors and the FPR and take care of it all
92camaroJoe
Jul 29, 2023 07:57 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
