Not Getting Spark or Fuel. I need help fast
Old Apr 26, 2010 | 04:21 PM
SSZ2891's Avatar
I just welded a new floor patch and didnt disconnect the battery. now my car wont start and its not getting any fuel or spark. just put in new plugs, cap, and rotor a week ago and i can hear fuel pump when first turning on key. what can i do. did i fry my comp.
Old Apr 26, 2010 | 07:27 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: Not Getting Spark or Fuel. I need help fast
Did you check fuel pressure? Unfortunately, it sounds like you may have damaged something electrical like the computer. I don't know exactly how to go about checking a computer to see if it has been damaged. I guess I would just start eliminating the alternatives. Try doing the paperclip trick and see if you can get the SES light to flash code 12 - ECU functional code.
Old Apr 26, 2010 | 08:35 PM
SSZ2891's Avatar
ok so i just did paper clip trick. it was 1 then pause then 2 then pause and kept doing this
InfernalVortex
Apr 20, 2021 11:31 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
