were does this vacuum line go?
Old Apr 26, 2010 | 11:40 PM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
I tired and tried, but simply cannot remember were it goes to. I can not find the other end or a broken line attached to anything under the hood, all I have is this one in the front of the tbi hanging out sucking air. I attached a pic, and the line in question is on the front of the tbi, on the drivers side, one of the thin plastic ones.
Old Apr 26, 2010 | 11:46 PM
frankwi's Avatar
Car: 90 Camaro RS
Re: were does this vacuum line go?
I believe that goes under the air breather cover.
Old Apr 26, 2010 | 11:57 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Forgive me if this is completely wrong as it has been a while since I've been under the hood of a stock TBI motor, but I believe there is a vacuum motor in the air filter cover that allows hot air off the exhaust manifolds to enter the motor. I think it goes there.
Old Apr 27, 2010 | 07:02 AM
jmberry's Avatar
That vacuum line should be running to the vapor canister which is usually located up in the corner driverside part of the engine bay. Look for a tall black cylinder type container. It stores and purges off fuel vapors from the fuel tank.
Old Apr 27, 2010 | 07:50 AM
timespy's Avatar
Car: 91 RS Convertible
Engine: Soon to be swapped
Transmission: Memphis performance 700r4
Axle/Gears: Soon to be changed
Jmberry is correct, it runs to the canister. It actually pulls alot of vacum so a worm clamp is a good thing to have on it.
Old Apr 27, 2010 | 08:34 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
+1
Old Apr 27, 2010 | 11:47 AM
Motopsyco's Avatar
thanx guys, yea I know the vacuum canister and there is a spout looking thing were looks like something should connect to, years ago I used to know these engine bays by heart, but have forgotten alot of it. thanx again guys
Old Apr 27, 2010 | 12:08 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Built91Z28 was correct. That line goes to the vacuum valve on the air cleaner which is not in the picture. The line that goes to the vapor canister is the one that connects to the throttle body right below where the PCV hose connects. That is pictured as being there in your pic. If you have open element or don't need the warm air you can just cap it off ( except in Cal. for smog )
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
