Got a really weird running issue
Car: 92 camaro
Engine: lo3 v8
Axle/Gears: 10 bolt posi 4.10
I have a 90 rs with the lo3 v8. I just put in a 91 305 caprice engine and replaced all the sensors, plugs, wires, etc.. It ran but not very well at all. So I started digging in and found out that the hose that hooks the pump onto the sending unit was shot so I replaced it. I also rebuilt the throttle body but nothing seems to fix my problem. Now the car fires right up and purs like a kitten but if I take her out on the road and mash the throttle it bogs, and sounds like its holding back bad. It runs great if I baby her up into the rpms, but if I get to heavy with the pedal it just runs like crap. Any Ideas?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Got a really weird running issue
Sounds to me like a bad Throttle Position Sensor. But I think that would be throwing a code. Are you sure the ignition timing was re-set correctly? And did you re-connect the black and tan wire afterward?
Car: 92 camaro
Engine: lo3 v8
When i set the timing i unhooked the black and tan wire, set it to 4 degrees advanced and hooked the wire back up. I figured that the idle would surge if the tps was bad.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The idle doesn't depend on the TPS, if I understand it correctly. The TPS is more like the accelerator pump of a carburetor.
You are correct sir. I was confusing the tps with the iac.
