91 305 TPI bucking problem, final attempt to fix
Old Apr 30, 2010 | 08:40 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
I'll try to keep this quick...
My formula has a wicked buck in the lower gears. In 1st its almost violent, in the upper gears it feels more like a repetitive stumble. Almost always occurs when holding constant lower RPM's, hard acceleration is fine. Another example, when you let off the gas in 1st, the front end drops right down like you hit the brakes. Terrible mileage too.
Relevant info:
-17-18 inches of vacuum at idle
-34 psi fuel pressure at idle w/ vac line connected, monitored while driving and the pressure never did anything erratic, so I've ruled out fuel pump
-new design III 19# injectors
-ignition timing properly set
-newer plugs, wires, entire distributor w/ module, ignition coil ohms out fine.
-newer O2 sensor, CTS, TPS voltage is fine
-NO CODES
This has been driving me crazy for 3 years. Now I think I might have a blown head gasket, and this probably helped that issue along. I'm about to take it to a mechanic, if I cannot figure this out soon. All I can think of is MAP, but without a code? If you have any idea at all, please help me out.
Old May 1, 2010 | 08:31 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 91 305 TPI bucking problem, final attempt to fix
Why aren't you posting this over in the TPI sub-forum? stock 305s generally never have any issues with head gaskets. A bad intake gasket is infinitely more likely.
Old May 2, 2010 | 01:19 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Thanks for the response,
I wasn't sure which forum to post it in, I don't know if it is a TPI specific problem. I certainly hope it isn't a head gasket! I'm still trying to determine what is going on with that, but I figured a constant knock/miss/buck would really stress a head gasket?
Took it for a lengthy drive last night, feels like half the cylinders just drop off at times. I'm at a loss for what to do next.
Old May 9, 2010 | 04:04 PM
cprepared125's Avatar
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
I have the exact same problem with my carbed 350. I've checked for vacuum leaks in the intake/carb gaskets with starting fluid, replaced plugs, wires, cap, rotor, even tried a different carb but still have the same issue
BlueIroc-Z
Jun 9, 2019 03:22 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
