Starting Problems
Old May 2, 2010 | 01:42 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Starting Problems
my car turns on and evrything but after its ran for a few minutes (15-25)...i turn it off and it strugles 2 turn on...or it just kills my battery if i force it...is the battery 2 small?...or do i need a flywheel with more teeth?...the og motor was a 5.0 high out with a manual transmission now its 5.7...help any info helps...I'm not tryin 2 replace sumthin that doesn't need 2 b replaced...
Old May 4, 2010 | 12:06 AM
Goany's Avatar
Re: Starting Problems
sounds to me like your starter is getting out. to be more specific the solenoid which doesnt wunna work my guess would to be to replace the starter if you get a mini torque you would never have the problem again but a starter replace should fix it.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
