Need help... no start when hot, but will crank
Old May 5, 2010 | 06:20 PM
racethesunlive's Avatar
Car: '92 Camaro
Hi all... when I try to start my camaro while the engine is hot the car cranks but refuses to fire up. I'm thinking it might be the injectors refusing to fire but I'm not really sure. I've been chasing this problem for awhile now and really need a reliable car soon.
Things tested:
-Confirmed spark to plugs using a timing light
-Confirmed constant 40ish PSI to fuel rail while priming and cranking
-Ohm'd all injectors both cold and hot, they show a consistent 16.8
-Will start with starter fluid in throttle body while hot
Things replaced:
-Ignition coil
-Entire distributor (includes new pickup coil, icm, cap, rotor)
-spark plugs
I'm not sure where to go or what to test from here.... I would assume something with the ECM and wiring to the injectors? Any help would be appreciated
Old May 10, 2010 | 07:10 PM
Car: '92 Camaro
Re: Need help... no start when hot, but will crank
Just to close this thread in case someone else has similar problems... the reman distributor I purchased from autozone had a dying ICM. One new Ignition Control Module (and a TPS adjustment) later and she fired up and ran every time, cold or hot. Drove me crazy trying to find out what could be broken after testing what felt like EVERYTHING!
long story short... don't always trust new parts from chain auto stores.
Old Jun 5, 2010 | 08:44 PM
tsram's Avatar
Car: 1990 Iroc Z
Engine: 355
Transmission: built 700R4
Axle/Gears: 3.73 posi
When yours acted up, did it seem like it wasn't fueling enough when cranking? Mine has the exact symptoms as yours did.
Old Jun 5, 2010 | 08:46 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
I TOLD YOU IT WAS THE ICM... ... ... j/k... but most of the ignition problems are ICM related... a few require a new pickup coil aka camshaft sensor..
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
Winchester1094
Aug 18, 2015 10:23 AM
