header install, no start now
Old May 6, 2010 | 04:29 PM
rx8camaro's Avatar
I did a header install, removed a.i.r, and ac removal on a 1992 z28. I starting up the car and let it warm up fully so i could retighten the header bolts when they cooled back down. so everything ran fine for 20 min. after i tried to restart the car nothing. i have crank but no start. one of our techs looked at some things and found no spark and no injector pulse width. he had me check the ecu fuse and it was ok. we looked at some things with the distributor and found the ignition control module had some corossion plus it was original and notorious for going bad. replaced and still no change. i might try the coil next. i dont' want to keep just throwing parts at it. any help would be apprecitated. sorry for my spelling lol.
Old May 6, 2010 | 04:50 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: header install, no start now
by coil do you mean pick-up coil? how does it look? you can ohm both. i don't remember what they're supposed to be off hand.
Old May 6, 2010 | 04:53 PM
rx8camaro's Avatar
yes the pick up coil. no cel lights either
racethesunlive's Avatar
Car: '92 Camaro
Check your grounds(on the back of the heads) and also make sure you have a constant 12v to the pink wire going to the ignition coil with your key in the "on" position. Also make sure that all of the wiring going to your starter is correct.
Old May 6, 2010 | 06:58 PM
wilkink's Avatar
Car: 1988 Pontiac GTA
Engine: L98 5.7L
Does it start up once the car is cooled down? If so, then it could be the heat soak with the starter. I am suffering from the same problem if that is the case. If it is heat soak, buy a mini-starter or a LT1 starter and put some heat wrap on it.
Old May 6, 2010 | 07:53 PM
rx8camaro's Avatar
i am not sure i will have to check it in the morning when its fully cooled down
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
justin57
Aug 20, 2015 07:05 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
