charging loss when warm
Old May 10, 2010 | 12:33 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
when i start my car it seems to charge right at 14 volts but when I run it for a while and things warm up it will drop as low as 10 according to my battery gauge. does this sound like an alternator or possibly just the belt? I know the belt probably isn't an exact fit as the smog pump was removed by the PO and there's not and idler or anything to hold its place. Also if someone could explain how to test the charging system I would appreciate it. I'm a definite noob when it comes to electrical stuff.
Old May 11, 2010 | 10:25 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Take Charge !
The dash gage is not always accurate.
You should monitor the voltage with a test instrument quality meter.
If the starter motor always turns at a normal rate there is probably no charging system problem.
Happy Racing!
Spin Me This Week … I’ll Spin You Next Week
Old May 11, 2010 | 10:34 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Take Charge !
If you drive to your local autzone they will do a charging system check for you at no cost.
You alternator might be on it's way out. I have seen them charge fine when cold, and not charge at all when they get hot. Usually and internal short in the stator from my understanding. When you gauge shows the voltage to be low, check it at the alternator with a DVOM, at the post w/ the larger red wire. You might just have a weak cable going from the alternator to the battery. I generally step that wire up in size anyway when you start adding electronics it's not sufficient.
RedLeader289
May 28, 2019 01:47 PM
3.8TransAM
Sep 27, 2015 08:37 PM
RS Reaper
Sep 27, 2015 07:04 PM
mfp189
Sep 27, 2015 09:25 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
