Would you replace this oil pan?
Old May 9, 2010 | 10:46 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
I'm in the process of upgrading heads/cam and thought since the motor is torn down, now would be a good time to replace this if necessary. What do you guys think?
Also, if I do have to replace the pan, if I remove the trans and flywheel, could I slide the pan out or do I have to lift the engine no matter what.
Thanks in advance
Last edited by oscarfromla; May 9, 2010 at 10:48 PM. Reason: Pictures needed to be added
Old May 9, 2010 | 10:52 PM
Stephen's Avatar
Car: 87 GTA
Re: Would you replace this oil pan?
You'll hafta lift the engine, no matter what.
Between the depth of the crankshaft & the oil pick-up, the engine will hafta go up, or the crossmember down.
The dent does look bad, but if it isn't leaking, I dunno it would be a major concern yet either.
Old May 10, 2010 | 02:02 AM
Guest
Guest
Posts: n/a
I've seen worse. The pickup for the pump should still be far enough behind that dent that it didnt get hit. I suppose if you have the time and the desire to go through it, replace it. I'm still putting mine off... someone thought the center of the pan said "JACK HERE".
As mentioned, you'll have to lift the engine up (or drop the kmember) to get the pan out. There is no other way.
Old May 10, 2010 | 08:03 AM
Damon's Avatar
Replace it becuase of that little "door ding"? Not unless it's leaking. Fix it whever you pull the motor for your next rebuild/performance upgrade.
Is it my imagination or a trick of the camera making it look like the sump on that pan is hanging down further than stock? Stock pan sump is nearly even with the bottom of the cross-memeber for the exact reason that dent happened in the first place.
Old May 10, 2010 | 11:13 PM
Car: 88 Iroc-Z
Axle/Gears: ??
The dents were probably caused since the car is dropped, and when I bought it, the previous owner was driving it around with spare tire donuts for front tires. The pan is hanging low cause I pulled all the bolts to set the timing chain cover properly.
Thanks for the replies, I'll probably end up leaving it and replacing if/when I go 383
Old May 11, 2010 | 10:37 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
You don't have to pull the trans/flexplate to get the pan out. I did my oil pan gasket 6 months ago. take off the distributor cap and jack the engine up till you can put the motor mount bolts back through the brackets above the mounts and set the engine down on the mounts. Remove starter and Y pipe. Rotate the engine around so the crank counter weight on the front of the crankshaft is up in the block and the pan will slide right out. Mine literally fell out on to the ground when I spun the crank.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
