engine, so frustrated
Old May 10, 2010 | 09:48 PM
Willishxc's Avatar
Car: 1985 Iroc-z Camaro
Engine: 350 V8
ok so ive been having problems for a while now with my 1989 camaro iroc z with the 350 v8, first it wouldnt idle after starting, i got that fixed via the iac.
then it would drive fine but when putting the pedal to the floor and above 3500rpms would hesitate or pulse before going through. Changed the fuel filter and fuel pump which fixed the problem for maybe two weeks.
now it has gotten progressively worse, tothe point where usually after driving about 20 min the car will not let me accelerate the rpms above 2500 which if i try car seems to stall but not turn off just slowly decelerate till i let off gas. i have to keep it around a steady 2000 rpms to drive and keep at speed. going up hills is terrible because i cant accelerate, and the longer i seem to drive the lower i can get the rpms to go up and sometimes it seems like the car just will not accelerate at all then starts to go again.
any help please, im thinking maybe the cat converter or i was told by a friend the egr? any backing to these claims or further solutions or things to try would be a great help, or if youd like any more information just ask
thanks
Old May 10, 2010 | 10:08 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: engine, so frustrated
ohm the injectors and pickup coil. check fuel pressure, codes. if the cat is clogged your exhaust will sound strange.
Old May 10, 2010 | 11:03 PM
Willishxc's Avatar
Engine: 350 V8
the fuel pressure was checked and the mechanic said its good, and the exhaust strange sounding in what way?
and i dont know how to ohm the injectors/pickup coil... first thirdgen only my second car haha not too mechanically savvy yet
Old May 10, 2010 | 11:14 PM
your exhaust would sound more like air blowing with little tone. i guess with little knowledge of cars you probably dont have an ohm meter. do you have a repair manual on the car? you can check codes with a paperclip and use the book to find the problem. injectors are a very common problem though. if you pay someone to fix it your looking at $400 or more.
Old May 11, 2010 | 06:36 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
If you think you have a cat restriction, pull out the o2 sensor before the cat, or loosen pipe before cat, and run it down the road, if problem goes away you found the culprit good luck..... dont give up
Old May 11, 2010 | 10:51 AM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
it may be a tranny filter if its an auto. try that. its not expensive if you do it yourself
jklein337
Sep 19, 2018 06:23 PM
Reddeath210
Oct 6, 2015 08:20 AM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
