Which distributor?
Old May 10, 2010 | 09:08 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Which distributor?
I replaced my dist. cap and rotor the other day and noticed a fair amount of rust under the cap. I cleaned it up with a wire brush as much as possible but I figure it should probably be replaced. I'll probably just pick one up from the junk yard but how do I know which one I need. Will a dizzy from an 87+ tbi car work on my 88 305 tpi? I didn't really see any part numbers or anything. Thanks.
Old May 10, 2010 | 09:12 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Which distributor?
Be aware that truck TBI distributors have a built-in, non-adjustable rev limiter set at 5250 rpm.
Old May 10, 2010 | 09:17 AM
Car: 1988 GTA
So what about a dist. from a tbi firebird? Last time I was at the local JY they had an 89 formula so I was thinking about robbing the dist. from that car if it is the same as the one used on tpi engines.
Old May 10, 2010 | 09:20 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That'll work just fine, assuming it's in good condition.
Old May 10, 2010 | 09:30 AM
Car: 1988 GTA
Thanks! That's exactly what I needed to know.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
