will only start when i let off the key
Old May 12, 2010 | 10:42 PM
v8 drift's Avatar
Car: 84 Z28
Engine: 355
Transmission: t56
Axle/Gears: 4 11
ive got an 84 Z28 its got about 150 thousand km on it its got a new msd ignition will turn over but will only fire when i let off the key its like the distributor isnt getin power till i move the key back from cranking position it takes a few tries but she will always fire it just randomly started doin this
Old May 12, 2010 | 11:56 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: will only start when i let off the key
Sounds like its not getting power with the key in the start position. See if you can put a test light on the power wire to the distributor to see if you have power while cranking.
Old May 13, 2010 | 12:00 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Dodgy Ign switch
eightsixseven
Dec 16, 2024 01:50 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
