SBC timing question.
Old May 13, 2010 | 08:57 PM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
Axle/Gears: 2.73 / Stock
So i just got my vortec heads put on my 350 block today. Got the valves adjusted and everything is running pretty well. My question, there is no timing tab on the front cover to time with or any mark or arrow for that matter. Is there a timing light or something that can time the car properly without a mark to show 0 from? Or will i absolutely have to find 0 like with the piston stop method for instance?
Old May 13, 2010 | 09:20 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: SBC timing question.
When I built my motor I found top dead with a magnetic base dial indicator with the heads off then used this pointer. It is adjustable so how accurate your timing is is up to you.
http://www.summitracing.com/parts/SUM-163700/
Old May 13, 2010 | 09:28 PM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
Thanks ill look into that, although i will be running nitrous when i get the engine running good and setup properly. So im trying to make sure the timing is correct as i know this is really important when running nos.
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
Bryan F
Aug 18, 2015 02:28 PM
wruiz
Aug 13, 2015 09:07 PM
