New Problem Weird RPM idle?
Old May 16, 2010 | 01:32 AM
dealbatony's Avatar
Car: Trans Am
Engine: V8 350 TPI
So lately my GTA has been acting up
i start the car n it'll start fine. Once started the RPM will accelerate and jump up n then it'll die down and sound like its gonna turn off, Then it'll jump up again, and so on. If i press the gas while on drive it will have no affect the car will just continue to act up. Even when on Park if i step on it the rpm wont stay up.
anyone familiar with an issue like this?
im getting really sick of always finding a new issue with my car.
every time i have money saved to fix my GTA's apperence or Mod, something new comes up!!!!!
Old May 16, 2010 | 12:28 PM
Vader's Avatar
Re: New Problem Weird RPM idle?
It might be a good idea to remove, clean, and lube the IAC, then clean up the TB and air passages. It shouldn't put much of a dent in your appearance budget.
Old May 16, 2010 | 12:39 PM
Pairof91rss's Avatar
Car: 1991 B4C-1991 RS
Engine: L98 5.7 TPI-LB9 5.0 TB
unplug each injector and check each one with an ohm meter. they sould all read right about 16 ohms each. Not sure if its the problem, but a good place to start ruling things out. Only takes about 10 minutes, and best of all its free if you have a multimeter... and if you dont, good reason to get one!
Old May 16, 2010 | 01:07 PM
dealbatony's Avatar
Car: Trans Am
Engine: V8 350 TPI
Ima just sell my GTA, I need something newer I'm tired of loading money into it just to keep it running..sad but oh well..
specialized
Jun 18, 2022 09:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
