90 bird w/noise
Old May 16, 2010 | 04:26 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
90 bird w/noise
Alright I finaly got it running down the road,but when I take off from a stop I get a grindy noise from the firewall.But only on takeoff up to about 10mpr.no sound in shifting and I wonder if the brakes could make all that noise.Its not been drove much in 5 years.I'll drive it somemore and see.oh yes the car only has 119xxx on it.Bobby
Old May 16, 2010 | 05:56 PM
vampyrico's Avatar
Car: 1985 Chevrolet Camaro
Engine: V8 lb9 i believe..
Axle/Gears: 10 bolt posi
Re: 90 bird w/noise
tranny could be slipping through first gear. if its an auto that is. brakes will usually smooth out after a little bit of a drive. just something to think about.
Old May 16, 2010 | 10:56 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 90 bird w/noise
sometimes it dose it and sometimes it dosn't.I've hardly had a chance to drive it sence I bought it.Was making ticking sounds on pass side and didn't want to stay running when put into gear.that was a loose distributer lock down nut.But this other sound sort of sounds like the wheels are rubbing on the wheel wall.But its not.Cant find anything loose and the wheel dosnt shake like its a bearing.I did see some kind of fluid around the front of the motor oils fine.I,ll check the tranny fluid again.Thanks for your reply!Bobby
87v6Bird
Jul 1, 2018 04:12 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Navy8125
Interior Parts Wanted
Sep 23, 2015 01:11 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
