i need help!!!!!!!!!!!!
Old May 17, 2010 | 04:41 PM
trvno1's Avatar
ok so im starting a new project, only problem is i dont know what im doing. this is gonna be my first engine re-biult, and i want it to go rite... i just invested in a 350ci motor that i wanna fix, currently it is tbi but i wanna make a change.i also invested in a 1989 camaro Tpi intake, with wiring harness and computer and everything to go along with it.. so here is my question.. what kind of camshaft,lifters,and heads should i use??
any knowledge anybody can give me is more that appreciated.. thanx
Old May 17, 2010 | 06:31 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: i need help!!!!!!!!!!!!
a hydraulic roller is best. call comp for a good grind. find some 113 heads. get some new 21lb injectors.
Old May 17, 2010 | 11:39 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
agreed, HR for sure, best advertised intake duration depends on the heads, valve springs and comp chip u have
