LT1 bad lifters??
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
LT1 bad lifters??
Hey guys, swapped an LT1 into my thirdgen.
Specs below:
Cam: LT4 hotcam
Rockers: Roller tip
Springs: LT4 Hotcam kit springs
Stock iron heads
Stock bottom end
I have a problem, i noticed (with the engine running) i have NO oil at the rockers on the passenger side. And i have ONE on the driver side thats oiling, and it's like a freakin machine gun (over the fenders at idle, like a hose at throttle). I pulled the rockers and pushrods. I checked the ones that didnt work, they were straight and clean. No marks on the rockers at all. Checked the ONE that worked, looked identical. Do i have multiple collapsed lifter or something? I dont have any knocking coming from the motor. Oil pressure on a mech gauge reads 50psi on a cold start, 30 when warm and increases with revs.
Any ideas guys?
Specs below:
Cam: LT4 hotcam
Rockers: Roller tip
Stock iron heads
Stock bottom end
Any ideas guys?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: LT1 bad lifters??
From a cold start on a new build, I've seen it take as long as 90 seconds to get oil out of all 16 pushrods. How long did you run yours?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
better pull the rockers off and make sure there's no galling from the pushrods rubbing the rockers without oil.
Back to your symptoms:
This is usually mis-adjusted rockers rather than bad lifters, but if you want to disassemble the lifters and clean them, it couldn't hurt. If you try this, you'll find it helps to make a small hook tool from a wire paperclip. The hook should be a 90 degree bend made with the tip of needlenose pliers. After the hook, you need about an inch of straight, then bend the rest into a small loop for a handle.
Car: 1987 Trans AM
I tryed readjusting a few with the motor on to make sure i didnt have my preload to high and smashing the lifters. With motor running, i loosened a few rockers till they ticked, tightened them just to where they stopped ticking, and then 1/4 turn of preload. I think I'll pull the intake today, and clean/soak the lifters over night if everything looks ok.
In the meantime, any other suggestions?
New2Chevy
Sep 28, 2015 12:35 AM
