manual steering box
Old May 18, 2010 | 08:38 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
manual steering box
i have a question. what manual steering box can i use in my car? i have an 84 camaro. is it one specific car or multiple. also how hard is it to install one of these? thanks guys!
Old May 18, 2010 | 09:29 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: manual steering box
You'll need a manual box from an 80's S10 truck. Make sure it had the 4 bolts on the top cover. All you need to do is remove you current box and swap the pitman arm from your Camaro's box to the S10 box and it bolts right up.
Old May 18, 2010 | 10:11 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I have also used manual boxes from Chevy Monza and Chevy Vega on thirdgens in the past.
Ditto about swapping the pitman arm.
Old May 18, 2010 | 11:02 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I forgot about the Vega. I should also add that the GMC S15's used the same box as the Chevy S10's. Blazers and Jimmy's of the same body style will probably work too if you can find one with a manual box.
Old May 18, 2010 | 07:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The older steering boxes such as those from the Vega, Monza and early S10's have a 3 bolt top cover. Although they will work, they're not a direct bolt in like the 4 bolt top cover late model versions.
The early ones have a different sized pitman arm shaft and unless you're swapping the steering shaft right at the rag joint, the input shaft is also smaller.
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
