knock sensor question
Old May 20, 2010 | 11:28 PM
whitechevy79's Avatar
Car: 84z28
Engine: 350/tpi
Transmission: 5 speed
Axle/Gears: posi
I have a 350 block with 305 heads and 305 tpi (1992) what knock sensor should I use. The block is like a 73 do i even have one hooked up? I will look.
Old May 21, 2010 | 01:28 AM
jackel200269's Avatar
Car: 92 camaro
Engine: lo3 v8
Axle/Gears: 10 bolt posi 4.10
Re: knock sensor question
Use the pre 1986 350 knock sensor. They are tunned to the block not the heads or induction. You might double check that year I gave you. They only make two different ones for the 350 so it will be the earlier one.
Old May 21, 2010 | 08:55 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
http://www.chevytalk.org/fusionbb/sh...?post/1462306/
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
