Fuel Problems
Fuel Problems
The only way my 89 Camaro RS is by spraying start fluid into the tbi. It will run usually as long as i keep giving it gas but as soon as i stop giving it gas the engine dies. I have replaced the idle air control, and fuel filter. I suspect the fuel pump. Anybody have any suggestions of anything i might try to make sure it is the fuel pump before i buy the pump and do the labor?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Fuel Problems
Do you hear the fuel pump running with the key on? Is anything comming out of the TB injectors when cranking?
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
