67-02 350 blocks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 67-02 350 blocks
Just talking about the block itself and nothing to do with the heads, crank, rods, pistons etc. Dipstick changed sides. One and 2 piece rear main seals. Flat tappet and roller lifters.
There were probably a lot of different casting changes between the blocks over the years based on all the different casting numbers.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
a big difference in the vortec block was the plastic timing cover which isn't interchangeable with the old style. it has a hole for the crank sensor.
theshackle
Mar 5, 2017 06:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
