intank pump relay
Old May 24, 2010 | 09:48 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
intank pump relay
can someone help narrow down which relay is the one for the intank fuel pump.
i posted a pic of them in an album in my profile cuz i cant figure out how to add an image to a post.
Old May 24, 2010 | 09:59 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: intank pump relay
Its the one with a thin red wire that doesnt connect to anything.
Old May 24, 2010 | 10:53 PM
TNT_Z28's Avatar
which one is that in the photo?
Old May 24, 2010 | 11:04 PM
travis401's Avatar
Car: 91 Camaro RS
None of those look like the fuel pump relay.....
Old May 24, 2010 | 11:35 PM
TNT_Z28's Avatar
one has to be. these are the only six i removed.
Old May 25, 2010 | 11:54 AM
TNT_Z28's Avatar
also does anyone know where to easily access the intank fuel pump wires inbetween the pump and the dash??
Old May 25, 2010 | 11:58 AM
travis401's Avatar
Car: 91 Camaro RS
Behind the back seat, under the carpet on the vertical part. Gray wire is pump power.
Old May 25, 2010 | 02:24 PM
TNT_Z28's Avatar
ok, i found 3 wires coming from the fuel tank.
a black one that is grounded below the back seat.
a pink one that im assuming is power
a tan one that might be to the fuel gauge?
would that make sence for a float style fuel gauge?
also would it be possible to rewire this without the relay? i was thinking of connecting the power to the fuse box.
Old May 25, 2010 | 09:47 PM
travis401's Avatar
Car: 91 Camaro RS
I guess they changed the wire colors at some point. Ive got a gray for power, black for ground, and purple for the sender. You can wire it up to one of those relays you have, all you need is a relay that has a constant, ground, 12v out and trigger.
Old May 25, 2010 | 10:03 PM
TNT_Z28's Avatar
could i use one of the ignition ports in the fuse box as the trigger?
Old May 25, 2010 | 10:11 PM
travis401's Avatar
Car: 91 Camaro RS
I used the IGN wire in the engine bay for mine, but yea, and switched 12v will work as the trigger.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Glowsock
Jan 9, 2017 04:06 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
