SHOULD THE ENGINE DIE
Old May 26, 2010 | 12:59 PM
memjr's Avatar
Car: 91 camaro z28
Engine: 5.0 tpi
should the engine die if you unplug the map sensor vacuum line? with the vacuum line unplugged the car will start and then immediately die. Is this normal?
Old May 26, 2010 | 01:52 PM
memjr's Avatar
Car: 91 camaro z28
Engine: 5.0 tpi
Re: SHOULD THE ENGINE DIE
any help???
Old May 26, 2010 | 02:49 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
I'd say that's probably normal. Have you googled what the MAP sensor is for? It's pretty damn important.
Old May 26, 2010 | 08:16 PM
memjr's Avatar
Car: 91 camaro z28
Engine: 5.0 tpi
i know what it does but on other sites with diffrent cars they have talked about unplugging the vacuum line and the car still idles!!! on alldata to test it, it says "unplug vacuum port, start car, then apply vacuum to whatever spec it said" i forgot. So i was just wandering surely someone has unplugged the vacuum line while the car is running or unplugged it and then tried to start the engine!!! What was the results??? Mabey someone will try it real quick. It would help me out alot and thx for any info!
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
