Loud Horrendous Noise Coming from the Rear
Old May 28, 2010 | 09:08 PM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Whenever I drive my RS for a while 5+ miles, a terrible humming/screeching noise comes from the rear of the car. Sometimes it does, sometimes it doesn't. It also usually shuts off with the car, but sometimes doesn't for a while. Once when it did it i crawled under my car and tried to find out what it was.
I ruled out:
Hatch Motor
Speakers
Rear End
My best guess is that it's the fuel pump, but heres the kicker, its new with <2000 miles on it. So could it be a simple relay or something? My TPS is also acting up if that helps.
Thanks for any help i get
Old May 30, 2010 | 09:08 AM
JackRs's Avatar
Car: 1991 Camaro RS
Re: Loud Horrendous Noise Coming from the Rear
Bump. So i figured out that it is the fuel pump.
And it never shuts off, so it'll just randomly come on for an hour when the car is off.
What could it be?
Old May 30, 2010 | 09:24 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
obviously a wiring problem.
Old May 30, 2010 | 09:30 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Before tracing wires, test the fuel pump relay. It could be shorted internally or the connecter could be fried like mine was.
Old May 30, 2010 | 09:32 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
The oil pressure sending unit above the oil filter will go bad and cause the fuel pump to run even when the car is off and the key is out. Unplug that, and go a day and see if it still comes on, then I'd say it's possibly the relay.
Old May 30, 2010 | 04:16 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
That relay is probably wired in a 'normally open' state. That means that unless you give it power, there is no connection. If it's randomly turning on, I'd look for problems along your IGN wire on the relay.
theshackle
Sep 17, 2020 08:26 AM
pimp2303
Jul 27, 2017 02:03 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
