What could this be?
Old May 29, 2010 | 11:07 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
What could this be?
Hello,
My IROC has been great, runs very smooth and no driving problems...One thing wierd did happen last week though.
I had started my car to go home from work, driven about 1 kilometer, and then all of a sudden the "service engine soon" light came on, engine lost power randomly, idle RPMs dropped to just over 500 (usually idles at 650ish), I was giving it gas and the power was greatly reduced, and the idle was very rough...I could tell the car was struggling to stay alive.
I parked the car for 5 minutes, and then started it up and no problem happened, I drove it for the next week all over with no problem. No check engine light or anything.
Then it randomly happened again tonight when I was going home from work...I drove about half a kilometer and the check engine light came on and the same thing happened...Parked the car for a minute, started it and the car drove fine...
Any idea what it could be?
I have done searches and come up with a few things...
-Fuel filter
-ECU or ECM??
-MAF sensor
I have no clue what this could be. Will there still be a check engine code even though the problem isn't happening at the moment?
Thanks !
Old May 29, 2010 | 11:45 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Re: What could this be?
Ok I just pulled the codes, and I'm getting code 33.
"High voltage at the MAF sensor"
This basically means a bad MAF sensor I'm guessing?
I'll get some of that spray that cleans the sensor tomorrow.
