1987 Pontiac Firebird Trans Am Dies
Want a title? Post!
Car: 1987 Firebird trans am
Engine: 305 V8 5.0L Carb
Axle/Gears: huh?
Hello my name is Aaron and I'm 15 years old and my car is a 1987 Pontiac Firebird Trans Am.
Recently, me and my mom drove up to the top of my road. There is a bump before getting on the main road. Well, I accelerated to get over the bump and get started to where I was going when, the car sputtered and completely shut off. So there I am, sitting dead in on-coming traffic. I coasted back into my road. I tried to start it again, and it started fine. It was fine the whole back down my 3 mile driveway. So I repeated this process and everything was fine until it died again at the same point. The bump is a VERY small incline where the main road has been paved more times than the side road.
My Car Info:
305 V8 5.0L Engine
No A/C, emissions control, washer fluid box, nor canister.
Carburetor
P.S. Carb was rebuilt in 2001. All fuses were replaced when I got the car so that no "almost-dead" fuses remained.
P.P.S. When I got home the second time, I gave full throttle in park to see if black smoke came out of exhaust pipes as had been reported by friends. The car backfired twice.
My Car Info:
305 V8 5.0L Engine
Carburetor
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: 1987 Pontiac Firebird Trans Am Dies
You said you were going up the top of your road, so a incline? Possibly not enough fuel and it all got pushed back to the back of the tank while on the incline? Is your fuel pump mechanical or electric?
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
most likely the fuel "pumps" are both mechanical and electric, mech on the block and elec in the tank
Want a title? Post!
Axle/Gears: huh?
Sorry for leaving the Q up. My grandpa found the issue. It's either the spark plugs or timing. AND, when I cleaned valve covers, I didn't put the gaskets back in perfect so its leaking gas too. When I fix the problem and it's running again I will post on here what it was and how to fix it for others like me that are bewildered by it.
hmm leaking gas through the valve covers!?...
Want a title? Post!
Axle/Gears: huh?
Yeah cause the gaskets aren't on correctly. but it will have to wait until i can buy some new ones.
Yeah Sony your right sorry for the confusion.
i was thinking thatd be 1 hell of a problem lol
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
