Alternative to vacuum advance?
Old Jun 1, 2010 | 11:13 PM
383Bandit's Avatar
Right now im running with just centrifugal advance because i dont have an ajustable vacuum advance. Summit is the only place to get the crane vacuum advance w/ the limiter plate as far as i know. Are there any alternatives so i wont waste so much fuel? Such as an adjustable electronic curve?
Old Jun 2, 2010 | 06:41 AM
Damon's Avatar
Re: Alternative to vacuum advance?
Not really. You would need something that could sense engine vacuum plus, obviously, an aftermarket ignition box capable of plugging into it and working with it.
You can always build your own limiter plate for the vacuum advance. An easy "eyeball" job is sufficient to get good results. Look at how much travel room there is between the "hook" end of the vacuum advance rod and the FORWARD edge of the slot it travels it (the edge that stops it's travel when vacuum is applied). Typically it will be about 3/16"-1/4" on a stock canister. Tack weld a piece of metal onto the canister arm that cuts that travel by about half and you'll be in the ballpark. If you go too far just file it out a little with a rat tail file to open it up again a little more, or break the welds, move it forward a little and tack it back down again.
Old Jun 2, 2010 | 08:17 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Or you could migrate to fuel injection and use an electronic advance distributor.
Old Jun 2, 2010 | 08:40 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
The only alternative (and its not cheap) is the Digital E-curve distributor I'm running. To change the amount of "centrifugal" or "vacuum" advance you have, you just take the cap off and turn a dial. I put them in quotes because there really is none of these. The distributor works entirely off of electronics. The rotor is fixed to the shaft in the distributor.
Old Jun 2, 2010 | 07:36 PM
383Bandit's Avatar
How much is the electronic system? I need some advance springs so thats why i wanted to buy the crane kit, but summit wont get it till the end of the month.. i need it now. I might just make the plate.. then where could i get the springs? Are they sold at the parts stores such as autozone?
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
