hard start but not the starter
Old Jun 2, 2010 | 07:08 PM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
car starts great when shes cold but when shes hot she's hard as hell to turn over
i put my mini starter in there from a 95 lt4, wrapped the y pipe from header to header under the oil pan and dropped the starter temp from 200 to 150
turned the timming down to 10 deg with the wire unhooked
i also tried using a torgue wrench on the crank to turn it over hot and cold it took 50# and 70# hot
im wondering if i have some internal issues with the motor, it has 7k on it but the guy who did the machine work was kind of a tard and dicked with me
im lookin at ideas of where to look or try only thing i got left is a remote solinoid, but all suggestions are welcome
Old Jun 3, 2010 | 10:56 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Re: hard start but not the starter
Check the timing when the car is cold, then when the car gets hot move the timing to GM specs. You timing is more advanced when your car is cold then when its hot.
Old Jun 4, 2010 | 03:15 PM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
when its hot its @10deg with the wire un hooked and 30ish with the wire hooked up
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
