car wont start
Old Jun 3, 2010 | 07:14 AM
Jaws031's Avatar
Car: 88 camaro
car wont start
Driving yesterday doing 55mph on the highway. Tried to give it some gas it wouldn't go it just cut off on me on the highway .What could it be for it not to start?
Old Jun 3, 2010 | 07:40 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: car wont start
Check for spark. Check for fuel. Most probably one or the other is absent.
Old Jun 3, 2010 | 08:27 AM
Greygoat's Avatar
Re: car wont start
I solved my no start issue, i had a bad fuel injector, you may want to check the ohms on each one.
Old Jun 3, 2010 | 03:25 PM
Jaws031's Avatar
Car: 88 camaro
Re: car wont start
Had a guy to look at it today, he said that it isn't getting no fire to it. Could it be the distributor?
Old Jun 3, 2010 | 03:36 PM
Greygoat's Avatar
Re: car wont start
There is a an electronic module when you take off the distributor cap. You can take the module to an auto parts store to see if it is working properly. The cost would be about 40 bux to replace.
Old Jun 3, 2010 | 10:51 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Re: car wont start
Check the ignition module, if that's good replace the coil.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
