valvetrain question
Old Jun 3, 2010 | 10:33 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
valvetrain question
can i reuse the lifters, pushrods, and rocker arms from my 1988 305 on a 1991 350?
Old Jun 3, 2010 | 11:03 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Re: valvetrain question
Same heads? You always want to place the rocker arms and push rods in the same place because they will wear down a lot faster. I would never reuse old lifters unless they are rollers.
Old Jun 3, 2010 | 11:16 PM
GTAman's Avatar
no, the 1991 350 is complete from plenum to oil pan. the lifters are hydraulic rollers. actually i don't have the lifters from the 305. i have to take the intake off this 1991 350 to check the conditions. the reason i ask this question is that my friend's father works at a place that makes rocker arms, and i have the old 305 heads with rocker arms and push rods. if the rocker arms are the same for both engines i was going to give him an arm off the 305 heads so i wouldn't have to loosen the valves on the 350 just in case they aren't the same or i just need to put the engine in asap (never adjusted valves before, a bit squeamish).
btw while i'm here talking about valvetrain, what is the OEM push rod length? i'm looking at comp cams' high energy push rod sets in my year one catalog and they give two sizes for OEM hydraulic roller cams: 7.195" and 7.2" lengths.
Old Jun 4, 2010 | 11:40 PM
GTAman's Avatar
bump! just took the intake off my donor engine and it looks all black like over cooked bacon! looks like new valvetrain stuff is in order.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
