part # for the maf power relay?
Old Jun 9, 2010 | 08:54 PM
hawkins's Avatar
i need to know the replacement part # for the maf power relay for an 1988 iroc 350 5.7 i can't find it at my local part store i get a code 33 and went thru the test procedures and found that the maf connector does not have any power so it say's to replace the relay help anyone plz
Old Aug 28, 2010 | 06:15 PM
motleykent's Avatar
Car: 1987 Chevrolet Camaro Iroc-Z
Transmission: B&M 700R4
Re: part # for the maf power relay?
You may be able to find the answer here.
https://www.thirdgen.org/forums/tpi/...ml#post4655720
Old Aug 29, 2010 | 02:04 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
I had the same problem a week ago and found that a BWD R4005Z was listed as a replacement for both the MAF Burn Off Relay and the MAF Power Relay. Most places I looked only list a replacement for the power relay and and not the burn off relay. so using the power relay should not be a problem for the burn off relay.
Old Aug 29, 2010 | 02:29 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Either go on line or find a store, But my local ADVANCE AUTO has found all my relay's and sensor's for my '87. Depends on the clerk, but a good one will dig till they find them.
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
