Loss of power with throttle
Old Jun 10, 2010 | 06:53 PM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
Transmission: 700R4 Transgo 2-3
Axle/Gears: 10 bolt 4.10s
My car is a 91 l98 a4. At first when it warmed up it would want to stall when I got on it. Then it would do it when it was warm. Now it does it all the time cold or hot. It starts everytime, it will rev with a little hesitation in park, but if I put it in gear it will want to stall out if I press the gas at all. I put a new fuel filter in it, a new iat sensor that went bad. I unplugged the map sensor still does it. I unplugged the tps and it idles up but still does it. I thought maybe the o2 when it did it hot but now that it does it all the time so I don't think so. Any one have any ideas. I have hooker short tubes into a 3" with out cats into a flowmaster.
Old Jun 10, 2010 | 06:56 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: Loss of power with throttle
Your timing is most likely out of wack. Reset it to 6 degrees.
Old Jul 14, 2010 | 08:15 PM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
It turned out to be two bad fuel injectors. One that read two ohms and one that read eleven ohms. I picked up a set of Bosch III's from Southbay and they are great.
theshackle
Sep 17, 2020 08:26 AM
sailtexas186548
Aug 24, 2015 10:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
