Anyone install cam bearings in a SBC?
Old Jun 10, 2010 | 09:51 PM
R3500's Avatar
I normally send my blocks out for prep and cam bearing installation, but this time I have a block that mics out fine and just needs a re-ring kit. It's a 1996 880 VORTEC 4bolt block.
The cam bearings are within clearance tolerance..but I noticed that bearing 1 and 2 have fine cracks through them (top side). Just ordered a cam bearing puller/installer. It will come with instructions but can anyone suggest a reference source that might discuss specifically the SBC bearing install? Does the rear block soft plug need to be removed for the last bearing R&R?
Old Jun 10, 2010 | 10:25 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
Transmission: tko 600
Axle/Gears: 12bolt 3.73
Re: Anyone install cam bearings in a SBC?
its not hard but i have a shop that puts em in for me that charged me less then the tool to do the job
Old Jun 10, 2010 | 10:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes unless you can find some way to pull it out.
I made a special tool that allowed me to change all the cam bearings except the rear one while the engine is still in the vehicle and the crank, rods, pistons are still in the block. It's tricky to get the bearings and tool in place but it's sure easier than pulling the engine to replace a failed bearing. It also helps when I have access to a hoist.
anesthes
Mar 10, 2016 10:35 PM
Wesly_66
Aug 26, 2015 09:55 PM
red90IROCls1
Aug 25, 2015 06:56 AM
sreZ28
Aug 14, 2015 07:48 PM
rsrmoore
Aug 7, 2015 08:44 PM
