ECM issue 1985 2.8L (PROM fault)
Old Jun 14, 2010 | 11:17 PM
crunchypoo's Avatar
Car: 1985 Camaro
Engine: 2.8L
Transmission: 5 spd manual
I'm having issues with my 1985 Camaro, 2.8L injected. The check engine light flickers both when I turn the key on and when the engine is running. I jumped the 12 pin connector and got a code 51 (PROM fault). I can clear the code by disconnecting the battery and then run the car with no issues, but when I turn it off and wait a minute, the problem re-appears all over again.
This issue is intermittent. I will act up for a few days, then go away for a few days and come back. I can't figure out why. Any ideas? I replaced the ECM a few years back, only to have this happen again. (I don't know what codes were present back then).
Can I resolve this by replacing the ECM (I don't know the part number, I haven't looked that far) or is there a secondary problem that could be causing this? Seems to me if it is intermittent, there could be a secondary cause, no? Is it possible that I replaced a faulty ECM with another faulty ECM?
Thanks in advance for any help!
stalkier
Dec 6, 2015 11:25 PM
Ducati900ss
Sep 2, 2015 09:05 AM
beast94
Aug 20, 2015 06:44 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 10, 2015 08:42 AM
